Level-In question
Home Forums Products Rackmount Level-In question
Viewing 4 reply threads
    • #105317
      Hi Italo
      I've connected my Eclipse with my amp's (Diezel Herbert) effect loop using Xlr-Jack cables,I've noticed that the meter of the level-in signal of the Eclipse is very low -24db/-18db maximum.
      The level-in gain is set to 0db and the pots of the channels of the Hebert are set 2 o'clock (70% of the volume).
      What is the problem?Did I miss something?What can I do to have a good signal?
      Thanks
      Max
    • #116894
      Max
      levels are a relative measure.
      Provided you have correctly soldered the cables (balanced to unbalanced- check the FAQ on our website), you can boost Eclipse input levels with GAINS (under LEVELS).
      I don't know which pot in your amp is also controlling the FX Send. Often it's the master out…..
      best
      I
    • #116895
      Thanks Italo!
      The cables are brand new (Proel,Die-Hard)
      (XLR Pins #1 & #3 to ?" Ground Connect XLR Pin #2 to ?" Tip. )
      I don't have any pots in the serial loop for the FX Send.The send level is managed by the master out located in the preamp section of the amp (set at 70%).
      The manual of my Diezel says that :"The individual channel volume controls determine the signal strength at the send jack.The range is -… to +10db.The output impedance is 4.7 kOhm"
      I've tried to boost the gain level of my Eclipse,and i've set the master out level of my preamp channel to 90%… the meter show -7db,but the clean tone of the amp is distorted.Tongue Tied
    • #127920
       If the front panel green LEDS light up, you're fine.
      The problem is in the way you set your amp and how it is designed really.
    • #127925
      Thanks a lot!Wink
      Max
