Light ring not lit
Home Forums Products Stompboxes Light ring not lit
Viewing 3 reply threads
    • #113821
      Apologies if this is a noob question. I’d really appreciate an answer though!
      I have my H9 set up in a pedal board with some midi switchable presets etc and it’s connected to a Roland expression pedal. So far so good.
      What I haven’t been able to figure is how to get the light ring to indicate when I am sweeping through parameters with my expression pedal. The display on the H9 may indicate numerically values that change as I work the expression pedal, but the light ring remains unlit. I could really do with a strong and simple visual indication of where I’m at from the light ring.
      Is anyone able to tell me how to get the ring lit so it lights up as I work the expression pedal?
      I pretty much do all editing on my H9 from my iPhone.
      Many thanks
      J
    • #144931
      Hey Guys, please come to the rescue of a fellow H9 user and offer me some wisdom.
    • #144934
      gkellum
        FeralPyg wrote:
        What I haven't been able to figure is how to get the light ring to indicate when I am sweeping through parameters with my expression pedal.
        There currently isn't a mechanism for doing that.  The light ring shows the value of a parameter that's being edited with the wheel.
        What you'd like it to do is to reflect the position of the expression pedal?
        • #144937
          Yes … just to answer your specific question.
      • #144936
        Thanks Gkellum for your response.
        What I did find by accident when I was using my H9’s volume swell expression setting was that this did cause the light ring to light up according to the travel of the expression pedal.
        So I suppose this is the only circumstance that the light ring can indicate motion of the expression pedal!?
