Home › Forums › Products › Stompboxes › Like a Stone preset for Pitchflex algorithm
October 10, 2013 at 5:03 pm #111141luchof26Participant
Has anybody gotten a similar sound to the record with the pitchflex algorithm in the pitchfactor pedal?.
Thanks,
Luis F.
October 10, 2013 at 11:27 pm #124898brockParticipant
It's just a Digitech Whammy ^OCT setting, and you pump the treadle with your pick attacks. Most are quick glides, with the occasional expressive slow glide to +1 Octave. You could replicate that sound with any number of PitchFactor algorithms. There were some factory presets in the "20's" like this, as I recall. The most obvious first choice would be PitchFlex, along with an expression pedal.
I've overwritten nearly all of my PitchFactor factory presets, but this should get you started. The Delay A, Delay B, and Speed / Scale settings are optional, but you can use them with the FLEX switch in Play mode (instead of an expression pedal). Not quite as expressive for this song's solo, but close. Tap the switch with your pick attacks, and mute the note just about when you release the switch.
LikeABrock
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = A(H): UNISN
Pitch B = B(H): UNISN
Delay A = H(T): 0.25S
Delay B = T(H): 0.05S
(encoder) = PITCHFLX / TMP OFF
Depth / Key = FLT: 0
Speed / Scale = SHAP: 5
Xnob = A(T): +1oct
Ynob = B(T): +1oct
Now just play like Tom Morello.
October 11, 2013 at 1:22 pm #124899luchof26Participant
Ill try it this weekend. Thanks for the suggestion mate. Br, Luis.
November 18, 2013 at 12:53 am #135829brockParticipant
I stumbled upon an auto-glide version that sounds similar to 'Like A Stone'. Palm muting between notes is essential. Sensitivity [Speed / Scale* knob] is a critical adjustment that depends on picking technique and PUP output.
AutoStone
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = A: UNISON
Pitch B = B: UNISON
Delay A = NO DELAY / 0 ms.
Delay B = NO DELAY / 0 ms.
(encoder) = HMODULATR/ TMP ON -or- OFF
Depth / Key = DP: +1 oct
Speed / Scale = SENS: 5-7*
Xnob = ENVELPE
Ynob = FBK: 0
November 18, 2013 at 1:28 pm #135830luchof26Participant
Great, Thanks!!!!.
