Home › Forums › Products › Stompboxes › List of small mixers with stereo EFX paths
August 21, 2018 at 11:50 am #114905Satch5150Participant
Let’s build a list of small(ish) mixers that can use a stereo external effects path, so you could use something like an H9 as a stereo AUX effect. “small” means home studio size to pocketable, less than 16 channels or whatever you think it means.
Alto ZMX862
Alto ZMX122FX (even has built in fx. yay)
Samson Sm-10 (1u rack, but still small-ish)
Your turn…
August 21, 2018 at 6:44 pm #149968Satch5150Participant
I found another one: a Eurorack module this time:
Blue lantern Stereo Sir Mix Alot
And just to be nice, here are links to the other items:
August 22, 2018 at 12:11 am #149972brockParticipant
I paid a premium for an (under)board-friendly mixer, with a basic set of features. But it’s augmented by some convoluted rack routing, plus an ancient line mixer.
RJM Mini Mixer: https://www.rjmmusic.com/mini-line-mixer/
Fostex 2016 Line Mixer: https://www.musicgoround.com/p/384960/used-fostex-2016-line-mixer
August 26, 2018 at 9:19 am #149997Satch5150Participant
I suppose all DJ mixers with send/return are stereo. Most are not “small” and definately not cheap. A filtered list at thomann:
https://m.thomann.de/nl/dj-mixer.html?keyFeature_50659=Yes&s=priceOtherwise the very small (recently discontinued) patchblocks pbmix3, though it has no aux faders: https://ask.audio/articles/review-patch-blocks-pbmix3
Art mx82
https://m.thomann.de/gb/art_mx822.htm
If you have infinite money: schertler arthur: http://www.schertler.com/en_IT/configurator/arthur-format48
A bunch of rane sm62s can be anything you want.
https://www.rane.com/sm26s.html-
August 26, 2018 at 7:47 pm #150000Satch5150Participant
Found another one: quite small. Bit expensive though. Radial Key Largo
August 27, 2018 at 4:37 pm #150001brysavaParticipant
The Radial Key Largo line mixer is the most transparent mixer anywhere near its class that I’ve ever used. That, and it’s compact size, make it an amazing choice for lots of applications, not just for keyboards. I can’t think of a better choice, unless you need a mic pre and/ or eq in your mixer. I love the fact that it only uses digital I/O where it is necessary–in it’s computer audio inferface section (96k/24 bit), and the rest of it is transparent analog. A great choice for using Eventide FX units, Eventide’s compact mic pre, etc.
August 27, 2018 at 8:17 pm #150002mistercharlieParticipant
This one is the size of a sheet of A4 paper. I bought one last week. Mono FX send, stereo return. I’m using it with a guitar, and an H9. It’s USB so you can also use it as an interface, and use the H9 to add effects to software instruments.
https://www.thomann.de/gb/soundcraft_notepad_12fx.htm
Another option is the Yamaha MG10.
August 29, 2018 at 7:29 am #150007Satch5150Participantmistercharlie wrote:Mono FX send, stereo return.
If that were OK, then there would be plenty of options. But this list is for devices that have stereo send and stereo return in something smaller than a table. Which is like a trying to find a foulmouthed unicorn. In the rain.
