Login User Name != Email Address
Home Forums Products Stompboxes Login User Name != Email Address
Viewing 14 reply threads
    • #181165
      jazzgear
        OK so my account profile doesn’t have a Username field, and it is not shown anywhere on my profile…. I’m sure I had to create one at some point.  So where do I find the Username?  I guess I’ll know it once this post becomes visible in the forum.  But why does one need to do this to find their username?
      • #181166
        PRSGUY513
          The “username” should be an email address that you used at the time.
        • #181168
          jazzgear
            Nope!  It clearly says “Not an email address” on the H90 Control App login prompt.  Plus I tried it and it didn’t work.  Anyway, non-issue now as I just used my forum name which is my username…as I learned from another post.
          • #181170
            Jeff Waldman
              I am having issues here too. This is ridiculous.
              Eventide, if a user has a Username it should be obvious on the My Account page. How about a “Username” field? That would be brilliant.
              I cannot get past “H90 Control wants to make changes.” My password is not working. I have tried changing my password. No luck. It must be the username that I have wrong. I no idea what my username is.
            • #181171
              jazzgear
                Now that you posted here just look at your name and that is the username — presumably without spaces
              • #181172
                jazzgear
                  <p style=”text-align: left;”>If it doesn’t work try entering exactly as displayed here in the forum.  But usually spaces are not allowed in usernames and passwords</p>
                • #181173
                  Jeff Waldman
                    No iteration of my name is working. Spaces, no spaces, caps, no caps. This should not be so difficult.
                    Thanks for your help.
                  • #181174
                    Jeff Waldman
                      Eventide,
                      When you are back in the office Monday please reply to this post. I am unable to use H90 Control because no username I am aware of works.
                      Thank you.
                    • #181177
                      PRSGUY513
                        Try tapping on your Avatar/Jeff Waldman which will take you to your forum profile info. Go down and tap edit and see what’s listed as your Nickname and Display name. On Display Name there should be a drop down menu that will have other choices. Or go down to the very bottom of the page and there’s a “Username” section that is greyed out. If any of the identifications is different than “Jeff Waldman” try those. Or if you recognize one as the right thing.
                        If none of this works, I would send an email off to support asap. It might still take until Monday, but could be faster. Good luck.
                      • #181183
                        Jeff Waldman
                          Thanks PRSGUY513. I tried everything. Nothing works. I’ll contact support.
                        • #181201
                          jazzgear
                            Ah Ok I see it…but honestly, from a UI perspective, that is not very intuitive to discern.
                          • #181203
                            Jeff Waldman
                              That user name does not work for me. I still can’t access H90 Control.
                            • #181204
                              jazzgear
                                By now you might need an Admin reset due to multiple failed log-in’s
                              • #181205
                                Jeff Waldman
                                  Eventide,
                                  I just derigistered my new H90. Please delete my account in full. I will create a new account once done.
                                  Thanks.
                                  • #181206
                                      I’ll reply to your support ticket and help resolve this there. Sorry for the inconvenience.
                                  • #181207
                                    Jeff Waldman
                                      Resolved.
                                      Thank you Eventide.
                                      • #181208
                                          You’re welcome. Thanks for your patience.
