Looking for a a H910 replacment
Home Forums Products Rackmount Looking for a a H910 replacment
Viewing 3 reply threads
    • #105295
      chrislaney
      This may be a dumb question but I have 2 of the old h910s and was wondering if anyone knows if the Eclipse has the detune with the short delay spread as the 910's do ??
    • #116847
      IDeangelis
      Try:
      295 FatAsCanB
      296 Micropitchshift
      297 MicropitchSlap
      these should do it. Adding some delay is at your taste.
      best
    • #116848
      chrislaney
      thanks for the reply, I don't own one as of yet but that sure helps, I felt as though there where a couple of presets that probably covered those bases so to speak.
    • #116849
      IDeangelis
       Chris
      that's one of the most known Eventide trick! From the 910 down to the H3000…to the 4000/7000, then Orville/Eclipse/H8000….. MICROPITCHSHIFTING!
      2 shifters, offset to +/- a few cents and one with longer delay than the other (we are in the 10>30 ms range).
      makes life….THICK!
      cheers
