Looper parameters keep resetting
Home Forums Products Stompboxes Looper parameters keep resetting
    • #183067
      StrolloSound
      Hello
      Having trouble with the looper setting “”Resolution” , “Max Length” and “Rec Speed”
      I have my preset saved so that when I power up I have:
      Resolution set to Smooth
      Max Length set to 60 sec
      Rec Speed at 2X
      Rec Speed is also mapped to HotKnob P
      When I record a loop, modify its speed, then stop and empty the loop,
      It seems that Resolution reverts to Octaves not Smooth
      Sometimes the Max Length will also change to 240s
      and the Rec Speed will reset to 1/2X
      Any insight as to why this would be happening?
      Thanks
    • #183084
      This might help with the expected behavior:
      https://www.eventideaudio.com/forums/topic/looper-oddity/#post-148873
      Also, the Looper has an extensive entry.  Lengthy, but you can find most everything in there:
      https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/algorithms/looper.html
