Low signal from AES output of H9000R and no ADAT
Home Forums Products Rackmount Low signal from AES output of H9000R and no ADAT
    • #115666
      J20056
        I am using the AES XLR output of the H90O0R abd the signal is extremly low, I can only get to -24dB in my digital mixer.
        I am unsure what to do?
        Also, I tried using the ADAt outputn instead, but there is no way in Emote to use the ADAt optical ports at all, seems like Emote is unaware that the H9000R has an ADAt I/O at all.
        Help!
      • #153523
        J20056
          I made some progress by changing the input sensitivity of the DAC and ADC but it’s weird that I have to do that because when using the digital inputs, there shouldn’t even be any DA or AD conversions. Anyways, it worked and I picked up a lot of db’s so I’m good.
          I also found how to select ADAT for the digital input/output but it appears that one has to decide whether you want to use ADAT, AES or SPDIF but apparently only, one can be used at a time. I’m ok with that as I work in 48k, so 8 digital I/O is plenty.
        • #153556
          jbamberg
            J20056 wrote:
            I made some progress by changing the input sensitivity of the DAC and ADC but it’s weird that I have to do that because when using the digital inputs, there shouldn’t even be any DA or AD conversions. Anyways, it worked and I picked up a lot of db’s so I’m good. I also found how to select ADAT for the digital input/output but it appears that one has to decide whether you want to use ADAT, AES or SPDIF but apparently only, one can be used at a time. I’m ok with that as I work in 48k, so 8 digital I/O is plenty.
            This is, as you say, very weird.  Changing the ADC/DAC settings should have no effect on the AES XLRs.  Could you send us your session so we can look at the routing?
            The setting for the digital audio mode is there because some resources are shared between the various digital audio interfaces, so it seemed simplest for users to decide on one they want to use.  Specifically, receivers are shared between the AES, XLR and SPDIF inputs so you can't run all of those at the same time.  However, more flexibility is possible than we currently offer the user.  For example, ADAT is routed separately from the other digital IO, so you could use all 8 ADAT channels and all 8 AES channels.  Or you could use XLRs and some, but not all, of the DB25 channels.  We are planning to re-think this in a software update.
          • #155272
            Wiinston
              Hi im having trouble locating the ADAT inputs within Emote. Can you Share with me how you were able to chose ADAT from input list? I see that i have to choose Adat over AES or SPDIF from your comment
            • #155281
              John Baylies
                You can select ADAT on the SESSIONS page, under the CLOCK tab, next to DA_MODE
                screenshot attached
