Home › Forums › Products › Stompboxes › M Audio EX-P Expression pedal doesnt work!
September 18, 2008 at 8:08 pm #105834
So i own a Timefactor and just bought a Modfactor. I had been using an ernie ball volume pedal with no problem. I bought 2 M Audio expression pedals since they were lighter, and i needed another for the MF. I tried switching the polarity switch and adjusting the pot to either ends, but no luck! Anyone else using the M Audio EX-P to control their Factors?
September 18, 2008 at 9:22 pm #117866
Id also like to point out that these have a hardwired, TRS stereo jack. Perhaps the jack needs to be TS(mono) to work?
September 18, 2008 at 9:43 pm #117867
The M audio EXP is hardwired with a stereo, TRS jack. Does the Factor need to see a TS/mono jack?
September 19, 2008 at 10:52 am #117868
I use one and it's fine. Be sure to flip the switch on the bottom. In one position, it won't work. Also, the range adjustment needs to be all the way in one direction….adjust both ways to see which works.
September 19, 2008 at 5:00 pm #129016
I did get them to work! Thanks for your reply.
September 19, 2008 at 7:16 pm #129018
Did it work with a TRS cable, or did you need a TS one? I'm making my own mini exp 'pedal' and am trying to find out if it need to be TRS or TS
September 29, 2009 at 8:28 pm #130262
how did you get it to work? I have one and I´m unable to make it, no matter wich selection of the bottom switch I make…
September 30, 2009 at 10:55 pm #119136
I've been using the EX-P on my PitchFactor without any problems.
October 11, 2009 at 5:19 pm #130355
TS works for my homemade ex-p (made from a crybaby!)
