Home › Forums › Products › Stompboxes › Make Modfactor, Pitchfactor swith work like Space
June 5, 2011 at 9:46 pm #107922
dafonk
ParticipantHi,
is it possible for the modfactor switchs to have the same behaviour as Space ?
Center and Right knob : Up/Down preset
Left knob : Active/InactiveThank you
June 6, 2011 at 3:49 pm #122234
We're thinking about it – depends on what people want …
June 6, 2011 at 5:41 pm #122236
timothyhill
MemberJust my opinion, and I've said as much before… I can see good things about both paradigms and I don't really have a preference, but…
What I'd really like is for all 4 Factors to work the same way.
June 6, 2011 at 5:55 pm #133483
EdDrake
ParticipantI've suggested this before but does it have to be one or the other? In other words is it possible that we can choose between the two options, maybe have it in the system settings as an option and we can pick the way we want the switches to behave?
June 6, 2011 at 6:16 pm #133484
caveman
ParticipantI can't give up the existing two presets available as the TF is now. Wouldn't mind a settable system option, though.
June 6, 2011 at 7:33 pm #122238
badmelonfarmer
ParticipantI think i do prefer the way Space works, i can see how the 2 banks in one view would be good for some people, less foot taps if you want to go between two settings in one song.
I agree that it should be consistent either way.
an option for either way would be good and keep most people happy.
personally not really an issue for me as I use a MIDI controller these days to control my effects.
June 6, 2011 at 7:58 pm #122239
It probably has to work one way or the other – I can see endless confusion otherwise if the way it works is defined by an invisible config thingy.
And, of course, twice as much maintenance and testing and Customer Support work for us …
June 7, 2011 at 11:16 am #133485
badmelonfarmer
ParticipantHmm, I Have a feeling that there is no right or wrong answer here…. You are gonna upset someone LOL.
Its just one of those things, can't keep everyone happy.
June 8, 2011 at 10:51 pm #133494
achaput
ModeratorIf you have Space and another Factor pedal you could have them select Presets on each other via MIDI. Then you have the choice of both interfaces at the same time.
June 9, 2011 at 2:31 am #133495
guitarlesson
MemberThat's what I do. The MIDI ports are the reason I bought my TF and MF. Connecting a MIDI controller frees me to use the 3 buttons on each exclusively for looping, tap tempos, etc.
June 9, 2011 at 2:33 am #133496
guitarlesson
Member…not exactly what you were suggesting, but YES! MIDI!
June 9, 2011 at 4:50 pm #133501
MarcoR
Participantachaput:
The problem is, when changing presets on Space you have a ridiculous lag time that will ruin it for your other factor pedals.
June 10, 2011 at 3:11 pm #122267
roverdog
ParticipantI've had my PF for a year and a half so I'm used to the way the switches work on that. I just received the Space and I'm fine with the way the switches work on that also but I do like having two presets available with one tap going between the two, instead of having to tap twice to change presets, like on the Space.
