Home › Forums › Products › Stompboxes › manual for H90 control?
- This topic has 17 replies, 8 voices, and was last updated 5 months, 1 week ago by
rperretta.
December 15, 2022 at 11:55 am #167742
eivaar
ParticipantI am very happy with the sound of my new H90, but I am struggling when trying to program it using the H90 control. It was really easy when I used the app on my H9…. Does it exist any manual for H90 control?
December 15, 2022 at 12:38 pm #167743
Sorry, there is currently no documentation for H90 Control.
If you are more specific with what you are struggling with I’d be happy to help give you some tips.
January 4, 2023 at 4:26 pm #168243
birthofahero
ParticipantI have a question about the app.
In the “Control Assignments” tab, can you explain what “Performance Parameter Mapping” is?
Thank you!
January 4, 2023 at 4:40 pm #168244
Sure thing. Performance parameters are functions that you would trigger using the P/A/B footswitches in perform mode. For example, this could be Program bypass or tap tempo, or a preset specific parameter such as the Looper’s transport controls.
The Performance Parameter Mapping tab allows you to map these parameters to external controllers like an aux switch or MIDI controller. This is useful if you’d like to use the onboard footswitches for active/bypass, and another controller for the preset specific parameters.
Let me know if you have any other questions.
May 20, 2023 at 4:44 pm #171371
MoPro
ParticipantIs there an ETA for an H90 Control manual?
May 23, 2023 at 9:56 am #171435
There is no ETA I can provide. Do you have any specific questions or issues I can help you with?
May 23, 2023 at 10:13 pm #171467
MoPro
ParticipantJust received the H90… Looking for the best source of info regarding the computer app. Don’t mind twisting the knobs, but don’t relish the thought of having to redo everything because I twisted the wrong one. One question I have now is if it is possible to set the taper, or response to expression pedal controllers?
Thanks for your help!
Al
May 24, 2023 at 10:10 am #171477
You should first calibrate your expression pedal from the system settings. This must be done using the H90 pedal UI: https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/system-menu/io.html
In H90 Control, you can set the range for any parameter by adjusting the highlighted circle around the parameter. For example, load Program 2 “Bedroom Vibes” and you’ll see that the Speed parameter is mapped to HotKnob A, but the range is limited from 4-7.5 Hz.
May 24, 2023 at 9:11 pm #171485
MoPro
ParticipantThank You!
I knew about the first part on the H90, but not the second part in the control app.
Thanks again for your help!
Al
May 25, 2023 at 9:39 am #171487
You’re welcome. You can also adjust the control range using the pedal if you like, instructions can be found here: https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/edit-modes/parameters.html#mapping
August 1, 2023 at 5:30 pm #172846
PEIPUNK
ParticipantDo I misunderstand the save function in H90 control? If I press it all my parameters revert to a different state.
Really need a manual guys, shouldn’t have to hit a message board for these basics.
August 2, 2023 at 1:07 pm #172868
Sorry, I am unsure what is happening from your description. If this is something you can reproduce, it’d be useful to get a screen recording of the issue and email support@eventide.com so I can have a better idea of what is happening.
There are a few ways to save in H90 Control:
Clicking the Save button in the top right will save the current state of the Program, that is the state of both Presets as well as mappings and other Program level settings. If you load the Program again, it should be in the exact state that it was saved.
You can also save a Preset by clicking the 3-dot icon next to the Preset’s name and selecting “Save to Library”. This will allow you to load the same Preset settings in a different Program.
April 4, 2024 at 3:33 pm #180524
halfachop
ParticipantStill no download for the manual????
April 4, 2024 at 3:37 pm #180525
There is an icon labeled “PDF” at the top left corner. You can right-click and download the PDF from there. https://cdn.eventideaudio.com/manuals/h90/1.7.5/index.html
August 16, 2024 at 2:46 pm #184358
skywriter
ParticipantThere is an icon labeled “PDF” at the top left corner. You can right-click and download the PDF from there. https://cdn.eventideaudio.com/manuals/h90/1.7.5/index.html
the PDF link does NOT show up on my iOS safari. but it does on OSX. wtf day one.
September 17, 2024 at 3:23 pm #184810
rperretta
ParticipantStill no manual for the control app? I looked for one as recently as today. Don’t see it.
I might remind you that the labor money you spend and the deleterious effect on your reputation in dealing with the question on line are adding up. It’s cheaper in the long run with positive customer satisfaction to do it.
I’m a retired CTO and have run software development projects to $20MM. Give me something fun to do and contract it out to me. Tongue only slightly in cheek 🙂 I’ll put together a team of top notch software engineers and get it done and done right using robust proven methodologies and development practices. Speaking of which, why didn’t the manual appear on the Gantt chart for the app? I’ll sure bet it didn’t. Didn’t marketing speak up? I sure wouldn’t have let that one slip. Just get it done. That way your customers won’t be sending wtf messages and your staff won’t be working below their rate. Meanwhile, I’ll playing blind man and the elephant out here. The hardware manual is 190 pages. You can’t expect to simply not write the app manual for a device that extensive in function and then expect your customers to just figure it out. I may sound annoyed but I am. I’m here to produce music, not decipher the Dead Sea Scrolls.
Eventide has a great name and has a history of selling great standard setting products that I and others believe in for good reason. Think of Tony Agnello. We believe in you. The Harmonizer was a landmark event in audio. Don’t sully that. Write the manual or get someone like me to do it. But by all means, don’t stumble on this one.
Randy P
September 17, 2024 at 3:25 pm #184811
H90 Control chapter of the manual can be found here: https://cdn.eventideaudio.com/manuals/h90/1.8.6/content/h90-control/index.html
September 17, 2024 at 8:14 pm #184813
rperretta
ParticipantOdd… I’m using a new H90. The only reference to the app appears once in the manual. After reading the other posts saying that there wasn’t an app manual, I was inclined not to look further for one.
oh well, thanks for the post with the manual chapter link. Mine doesn’t have that chapter but I’m learning the box fast.One thing I will give you credit for, I got a good laugh from the algorithm guide where it describes the bouquet delay aka Bucket,
Could it be that someone at Eventide is a fan of the old British sitcom “Keeping up appearances”? it’s about a suburban woman whose life is all about appearing to be higher class than she is. She married a fellow named bucket and insists that she be called bouquet. I wonder if the remark in the manual about pronunciation isn’t a reference to that. Well done, whoever thought of that one.
I would at least suggest that somewhere in the manual for the H90 that you make a reference to the link for the control app chapter that you sent me. From the posts, it seems to be an item of considerable interest.<span style=”font-size: inherit;”>.</span>
Randy
