Mapping MIDI controller to parameters
Home Forums Products Rackmount Mapping MIDI controller to parameters
Viewing 3 reply threads
    • #171947
      klango
        I’m trying to map a fader from a hardware keyboard to a parameter in Emote by sending cc21 on channel 1. For some reason Emote sees this as a program change message on channel 2.  The parameter does move according to the fader, but when I assign several faders to various parameters at some point they all stop working.
        Any ideas why this is happening?
      • #171949
          First, what controller are you using and how is it connected to the H9k?
          When you say “For some reason Emote sees this as a program change message on channel 2” what do you mean? Are you using Learn and it shows the incorrect MIDI data in Emote?
          Can you try using a MIDI monitor from your controller to make sure it isn’t sending the unwanted MIDI data?
        • #171960
          klango
            Thank you for your reply.
            It’s a fader on keyboard that is connected to the MIDI in of the H9000R.
            The fader sends controller data on controller #21 channel 1, as I verified on a Midi monitor.
            I’m mapping by putting a parameter in learn mode, moving the fader and apparently the incoming data is seen as program change on MIDI channel 2.
            The same happens when I send controller data from MAX.
          • #171967
              Thanks for the information. I have not been able to reproduce this, Learn will always show the correct MIDI information it is receiving.
              Does this happen with a specific algorithm/parameter?
              Can you test a different MIDI controller?
