Match EQ Not Working In Samplitude Pro X3 Suite
Home Forums Products Plug-Ins Match EQ Not Working In Samplitude Pro X3 Suite
Viewing 6 reply threads
    • #114409
      JesusSheep
      Match EQ Not Working In Samplitude Pro X3 Suite.
    • #147396
      DGillespie
      Can you give us some more information?  Are you on Mac or Windows?  Using VST2 or VST3?  How are you trying to make it work, and why do you believe it is failing?
      Dan
    • #147442
      JesusSheep
      Using Samplitude demo with 2 extra tracks Ove is sub mix other is aux side chain.
      Sone Times Works
    • #147443
      JesusSheep
      Windows 10. If I replace efx_comp with  Elevate in the mixer  overloads my computer too. With the samplitude Pro X3 Suite Demos.
    • #147444
      JesusSheep
      It seems if I Side chain it wants an ready rendered track to analize. Using  105 VST 3.
    • #147447
      DGillespie
      Hi JesusSheep,
      Are you trying to match one track to another track?  You need two full tracks of audio, the one that you're trying to EQ, and the one you're trying to match.
      Thanks,
      Dan
    • #147544
      JesusSheep
      I Sent my info both to support and website
