Home › Forums › Products › Stompboxes › MaxOut Upgrade: Upgrade only available to a single device?
December 18, 2014 at 12:34 pm #112163bwade83Member
Hey there, although the MaxOut email I received seemed to point toward the answer I just want to be sure:
The MaxOut Upgrade is only for one device per account? If you have two H9 Cores, for instance, will they both be upgraded upon buying the required number of algorithms?
Thanks guys and classy move offering this program!
December 18, 2014 at 2:56 pm #127178gkellumParticipant
Yes, the MaxOut Upgrade is only for one device per account, but of course once one of your units is maxed, you will be able to use all of the algorithms on your other unit as well although it will remain a Core.
December 20, 2014 at 9:37 pm #127197bwade83Member
Thanks for clearing that up for me sir!
December 22, 2014 at 5:33 pm #127210dafonkParticipant
Is it possible to have access to all the Algorithm from the H9 core alone without the H9 control if you have an H9 max ?
If yes, how to load the algorithm into the H9 core ?
Thank you.
December 22, 2014 at 5:39 pm #137842gkellumParticipant
dafonk:
I don't understand the question. Are you asking can you install all of the algorithms onto an H9 Core if you have a Max without using H9 Control? No, you need to use H9 Control to install the algorithms on the H9 Core. Or are you asking can you change the active algorithm on your H9 Core without using H9 Control? Yes, if you press the Preset switch twice, it switches from changing presets to changing algorithms.
December 22, 2014 at 5:49 pm #137843dafonkParticipant
I have an H9 MAX and I want to eventually purchase an H9 core tp use the algorithms.
Can I load the algorithms into the H9 Core and then use the H9 core with all the algorithms ?
Thank you. -
December 22, 2014 at 5:53 pm #137844gkellumParticipant
dafonk:
Yes, when you register your new H9 Core to your account, our server will know you have an H9 Max, and as part of the registration process, it will install all of the algorithms from Max onto your H9 Core.
December 22, 2014 at 6:05 pm #137845dafonkParticipant
Thank you. H9 Core, on the way…
