October 28, 2008 at 10:49 pm #105900
agapi
Memberhello ,
do you know where can i buy a memory card for an Eventide dsp 4000 for soring presets.(pcmcia card that is)
Furthermore,
can i buy an adapter pcmcia to another memory type ex sd cause they are much cheaper and less trouble.
will this work
thank you
October 29, 2008 at 8:46 am #117981
IDeangelis
MemberHI Agapi
the 4000/7000/Orville Harmonizers do not support Compact Flash Cards & adapters. You need a PCMCIA with them.
You can try Googling for PCMCIA Cards. Last breand we used was Centennial; they make rechargable cards too.
All the best
I
October 29, 2008 at 1:04 pm #117982
agapi
Memberthank a lot .
were really helpful.
a few more questions now. What is the max capacity the dsp 4000 supports (for the pcmcia card i mean ) and why should i need a rechargable one. Please explaim
Again thank you for your help and your immediate response
October 29, 2008 at 1:30 pm #129132
IDeangelis
MemberI believe the max. external memory the 4000 can address is 4 megabytes. The manual may report this. In real life I have found that a 1 or 2 MB card is way more than enough for hundreds of presets.
You don't need rechargable cards. I only happened to advice you that brand because I have a rechargable one they made. The advantage is that you'll never need to buy and change an internal battery. The downside though is that the card should be inserted in the +powered on+ unit to be recharged. If left in the 4000 for long time, without powering the unit off, it may be completely discharged. My experience with these cards is 100% positive though. Never had a single problem as I had with other brands.
all the best
I
October 29, 2008 at 1:32 pm #129133
IDeangelis
Member" If left in the 4000 for long time, without powering the unit off, it may be completely discharged"
SORRY! I meant without powering the unit ON!
December 25, 2008 at 7:53 pm #129226
ulfiyya
ParticipantHi,
Can the H 8000 read presets from gtr 4000 via memory card or vsigfile?
Thanks,
Mo, -
December 31, 2008 at 2:29 pm #129232
drooney
MemberHi Mo,
The H8000, H7600 or Orville cannot read the PCMCIA memory cards that were used with earlier models such as the DSP4000 and DSP7000 series. The newer models use compact flash and aren't compatible. Sig files aren't transferrable either as the operating systems to support both are completely different.
Happy New Year!
January 2, 2009 at 10:25 am #129233
ulfiyya
ParticipantThanks!
And how can i do it ? do you heave a propositin?
Happy new year!!!
ulfiyya
January 2, 2009 at 4:33 pm #129234
With deepest respect to drooney, the newer products (H8000,7600) should be able to read PCMCIA cards from older units, although this will not have been tested much, so there may be the the odd issue.
Note that these later units include improved versions of most of the presets in the earlier units, so there will not be many reasons to transfer them.
Sigfile should in general transfer, but there may be some incompatabilities due to changes in the modules.
January 5, 2009 at 4:23 pm #129243
drooney
MemberThanks for the correct information Nick. My apologies Ulfiyya!
January 30, 2009 at 2:59 pm #129331
ulfiyya
ParticipantNo problem. Thanks for you fellas!
ulfiyya
February 1, 2009 at 12:47 pm #129333
ulfiyya
ParticipantHi,
Do you heave a GTR or H 8000?
ulfiyya
February 2, 2009 at 3:39 pm #129336
drooney
MemberHi,
We don't sell previously owned products or directly to customers. If you are looking for previously owned Eventide products, you should check on Ebay or your local retailer that may do so.
Best of luck!
March 10, 2009 at 11:30 am #129476
ulfiyya
ParticipantHi,
I mine do you heaved for your self?
But away
Where can i find the serial of grt 4000 in side the machine outside is nothing to find!
Thanks
March 10, 2009 at 4:13 pm #129479
drooney
MemberThe GTR didn't include a serial port and it is not possible to add one now, as the motherboard and operating system is not designed for one.
March 10, 2009 at 4:31 pm #129480
ulfiyya
ParticipantI mine serial number!
ulfiyya
March 10, 2009 at 5:41 pm #129481
drooney
MemberIf your GTR4000 still has the serial number that it was tagged with when it left our factory, you should be able to find it on a silver sticker. Normally these are placed on the left panel of the unit, but you may find it on the back panel, right panel or top or bottom cover.
If you are still unable to find this sticker or tag that is clearly identified with "Eventide Inc", then at some point in this unit's history the serial number sticker was removed.
March 11, 2009 at 3:56 pm #129484
ulfiyya
ParticipantThanks Rooney!!!
ulfiyya
