memory card Midi
Home › Forums › Products › Rackmount › memory card Midi
    • #111492
      lionelred
        Hi There
         I have been struggling for a few days trying to control the eclipse via DAW.
        I took the memory card out and midi worked!?!?
        is that normal for midi to be disabled when the memory card is inserted?
      • #125624
          It is not normal – there is no direct connection between the two. The memory card is scanned for changes on a regular basis – it is possible that it is corrupted in some way and consuming enough system resources that MIDI cannot work.
          But, it would appear that the solution is in your hands.
