Mic Pre Modification – Not
Home › Forums › Products › Rackmount › Mic Pre Modification – Not
Viewing 9 reply threads
    • #105810
      In hopes of helping to justify the cost of upgrading my Orville I looked into what could be done to make the unit sound better. The answer is not much.
      Nonetheless I've often found myself wishing that the Orville had mic pres built in and those can get real pricey. So if you're like me and happen to poke around Audio Upgrades site you'll find that they sell mic pre cards the size of a couple coins for not that many…
      I just learned that:
      Eventide doesn't do mods, which void any warranties.
      The inside of a digital box like the harmonizers has too much clock noise and what have you to just drop an analog card into it and expect to get a good sound.
      Another great idea all shot to hell.
    • #117826
      Sonic Nomad
         I don't get it.
        Why put a Mic pre into the the Eventide? What about phantom power and if the mic pre fails then the the Eventide fails.
        In my experience you cannot build a "decent" pre that small.  I highly recommend you go out and buy a decent pre amp. Also if you spend anything less thatn US$1000 on a pre then you have proberbly bough one whose sound does not do justice to your signal path and you will be feeding sub-standard sound to the Eventide.
        Personally I spent some time trying out various options and have invseted in a serious signal path. The reason being if I record synths, samples, vocals, guitars and anything else it will sound good.
        The pre-amps i landed up getting are Great River ME-1NV's as I like their sound and I can also use them when mixing by running my master buss out into them to add some color/flavor if you like. They rest of the chain is a Great River MAQ-2NV Mastering EQ and a SPL Kultube with Luhndahl Transformers. This chain gets used for mastering as well with my H8000 as well.
        So the mastering chain looks like this;
        ME-1NV -> MAQ-2NV – > Kultube -> H8000 = Classy.
        Also another reason you would not want to build a pre-amp into the Eventide is to add other processing to the chain before it reaching the Eventide like a bit of analog compression. Another thing to consider is you will devalue your unit quicker rather than add value by doing some obscure non stardard modification to you unit.
      • #117827
        Nice read Nomad.
      • #117828
        Synths, an SM57, and some cheaper condenser mics that can use batteries don't require phantom power.
        You can't build a pre with any character that small, but something for drum overheads and such is certainly possible.
        I love my Great River pre too. I first heard about it from a producer who used on a whole mix when mastering along with a Manley Slam. That is a bit much, but the sound that Great River gets from ringing a large transformer is superb for rock.
        My mastering chain is a Manley Vari-Mu and Massive Passive then I switch in Apogee's soft limit function. I've tried peak limiting with a new Chandler EMI and a UA 1178, but they both mess up the sound. So now I use them for tracking different things. My Manley Gold mic has enough gain that I use it straight in to a compressor without a pre. So you can see that I also like a little analog compression prior to going digital.
        What is a Kultube?
        The modification can't be done practically. It was just an idea that I posted here as a warning.
      • #128977
        ThreeFingersOfLove
          Hi Mike,
          if you want a warm analog compression before going digital why don't you try the AnaMod ATS-1? You can control how much is fed into the Orville with the Output control (so that you don't overload its converters). Just an idea.
          Regards,
          Yannis
        • #128978
          Sonic Nomad
             Mike,
            The Kultube is a rather nice compressor from German compant SPL. The same guys who make the Transient Designer. They make mastering consoles and all sorts of great alanog gear.
          • #128990
            ThreeFingersOfLove:
            Hi Mike,
            Regards,
            Yannis
            Hi Yannis:
            Four reasons:
            1) I have too many expensive compressors now from trying to follow Manley's instructions on mastering and my own ideas about dynamics (do whatever it takes to make the sound move).
            It isn't a mystery why Manley recommends an analog peak limiter. Maybe their ELOP & Slam second stage will put an edge on the sound without mucking things up, but Apogee's soft limit is a lot cheaper since I already have it on a couple converters; does the job; and is transparent. Though I do like the solid state crunch that the UA1178 can add, that unit and the Chandler compressor just muddy up a mix when used after the Vari-Mu.
            I didn't mention that I have an Avalon UA pres purchased when I only had mono mics. Since those got stolen, I only use stereo mics now.
            2) Nuendo comes with a tape compression plug-in, Dynamo(?) that sounds great on guitars, but not whole mixes.
            3) Warm, I got too much of with all the tube gear. I also have a UA mic tube pre that is handy for DI, talkback, and side on M/S vocal tracks with the Avalon on mid.
            4) I am almost out of space for these expensive toys and should have plenty enough already to do the job.
            Though I would like to hear how Chandler's single channel EQ fattens up sound with feedback. This should be reproducible in principle with a harmonizer EQ patch and in practice by adding: compression, harmonix, and distortion (in moderation) modules.
            Harmonizers I got. The idea was one for the studio and one for live work. After someone who should be dead stole my mics, I got sick of the whole field. If I was sure of who it was they would be dead and I would be in jail.
            How do we post patches here? Or do we?
            TC's AES mastering papers would tend to recommend the Anamod ATS-1 since nowadays a lot of music that isn't on tape tends to distort consumer gear. You may not hit a peak when mastering, but interpolation on the listener's gear can cause it to happen with ugly consequences. Mastering has gotten to be a war of Sound Pressure Levels. There was something to said for the limitations imposed by disk cutters – too loud and they skidded off the platter.
            Thanks;
            Mike
          • #128993
            ThreeFingersOfLove
              Hi Mike..
              Wow, you seem to have very cool stuff so I am pretty sure you have the warmth part covered. I only suggested the Anamod because it can do something that I did some years ago with a 1 euro cassette on a cheap Sanyo hi-fi. I recorded a JP-8000 but this time I hit it really hard with the levels into the red area and everything. After I got to hear the tape the low and mid frequencies were absolutely awesome. Of course, it lacked clarity simply because due to the tape characteristics the high frequencies got squished. I thought that maybe I could retain some of the original clarity by mixing some dry signal in. In short, nothing less than parallel compression. The AnaMod can do this with the BIAS control so, ter the Manley Massive Passive, it's next on my shopping list.. 🙂
              You are right about peaks on mastering – it also seems ironic that lots of people have those excellent converters and yet they try to shove all thesignal into the last 1 bit.
              Too bad about the microphones….. 🙁 what can I say? It's very sad when things get stolen, it makes you think whether we need to hire security stuff to keep an eye on racks and mikes.
              Regards, Yannis
            • #128994
              Hi Yannis:
              I should be working with my audio stuff instead of being online. But I can't get this notion out of my head that there is way to use Harmonizers as character added channel strips – like tube and Great River pres. Bill Putnam Jr., the CEO and chief bottle washer of United Audio, claimed in an interview that they are using Physical Modeling and not Impulse Response like I had thought on their plug-ins. Of course UA puts the old circuit diagrams into DSP form first.
              I've done Karplus-String Physical Modeling on the Orville. It is a very simple way to get a plucked string effect with a resonant delay line. However to make a Harmonizer sound like a Great River mic pre would probably require weeks of tweaking a lot of modules. Ironically in power lines at least loaded transformers produce odd and not even harmonics like triode tubes.
              It may be possible to digitally get the best of all possible mic pres all selectable in one large patch. I've studied the Harmonizer patches of classic gear and they just translate the analog signal path into DSP without trying to capture any special sonic characteristics.
              The Bose L1 Tonematch has some features that are halfway to the future of Public Address. You tell it the instrument and it sets the tone control range accordingly along with some undocumented slight EQ'ing. That much could easily be made into a Harmonizer patch. In the near future a sound man will send a signal through their PA to ascertain the room acoustics, then the reverb and EQ will be adjusted automatically to that used in the studio using Impulse Response modeling. As for stadiums… use weapons grade speakers.
              Back in the dark ages of audio, a couple who had their own act tipped me off to always mastering to cassette tape in the red. One famous (at the time) producer had a channel on his mixing board modified to something like +12 dB to make sure he got tape saturation on guitars. The Nuendo tape saturation plug-in is called Magneto and not Dynamo like I wrote.
              Chandler has the Curve Bender, a stereo EQ with the same layout as the Massive Passive. You might want to listen to it before buying a Massive Passive. I haven't heard the thing so I can't say much more than it looks like a serious competitor with a few more features. I think a big consideration is not to load up on too much tube gear (like I did) because it can make the sound muddy. Tubes have too slow of a response time for peak limiting and this limitation is probably applicable to general clarity. With a DAW some tube gear is essential to get rid of that shrill or crystal clear digital tone.
              This place should be called "Klepto Rica." Seven years in LA (but not Tibet) and nothing disappeared.
              Cheers;
              Mike
            • #128995
              Sonic Nomad:
              ?Mike,?
              Sounds cool. I Googled the thing right after I asked what it was. It also does tube simulation and other things besides compression. The name is definitely weird though.
              I really think that if they had the man or woman power to do it, Eventide would come up with all the modules needed to enable us to do anything imaginable with audio. It isn't like Eventide has a product line that would be endangered and their design philosophy is one of complete flexibility. So let's all chip in and buy Nick a large supply of Methedrine…
              Cheers;
              Mike
