Micropitch delay help
Home Forums Products Stompboxes Micropitch delay help
Viewing 3 reply threads
    • #164191
      nrx313
        Hello to all. I’m a bit embarassed to post this but I need some assistance with my new Micropitch delay. I purchased it specifically to attain the 90’s EVH sound. I just want to edit the pitch shift on the  first preset which is the H3000 and I’m stumped. Yes, I’ve watched as many videos as I can on the device. I think my age is showing as I’m just not technically adept. I just want to dial back the pitch shift effect as it sounds like “too much” to me. Any help for this old geezer is appreciated!
      • #164192
        joecozzi
          Hello nrx313, the simplest solution is to back off on the Mix knob. This will allow the dry signal to emerge and lower the volume of the detuned voices. I would say starting out on the first preset and moving the Mix knob to the 12 o’clock position is a good start. After that, you can try reducing the amount of detune for each voice.
        • #164194
          nrx313
            Thanks Joe. I get what you mean but I’m looking to permanently edit that 1st preset and I’m not sure how to do it. I definetly want to reduce the amount of detune and then play with the delay setting also
          • #164195
            joecozzi
              Go to 35:23 of this video:
