MicroPitch Delay – Tech 21 MIDI MONGOOSE controller
Home Forums Products Stompboxes MicroPitch Delay – Tech 21 MIDI MONGOOSE controller
    • #168183
      Baccetti
        I tried to connect MicroPitch Delay and Tech 21 MIDI MONGOOSE controller and I have noticed an issue that in my opinion can be resolved with an update. The Eventide pedal has presets set from 1-127, and the MONGOOSE midi pedal has presets set from 0-127. As you can see in the attached video, key 1 on the mongoose pedal does not react. Only button 2 activates preset 1 on the Eventide pedal and then button 3 on the mongoose pedal activates preset 2 on the Eventide pedal and so on. Is it possible to make some updates on MicroPitch Delay to resolve this issue?
        Thank you, Anže
      • #168198
        joecozzi
          Hello Baccetti,
          Presently, there are no plans to add this capability, but the team is aware this could be useful. Other users that have faced this challenge have been able to reconfigure their MIDI controllers to provide the offset instead of the pedal. Looking at the MIDI Mongoose manual it does not look like it has this capability. Regardless, thanks for letting us know.
        • #189683
          MassiMax
            I connect midi controller Advance OP128 (0-127) in to MicroPitch Delay and <span style=”font-size: inherit;”>i have the same problem!</span>
            is there really no solution?
            Thanks
