MicroPitch Out1 + Out2 to TRS
Home Forums Products Stompboxes MicroPitch Out1 + Out2 to TRS
Viewing 3 reply threads
    • #162920
      P9
      Any reason that I should not take Out1 and Out2 from my Miropitch and combine them into a TRS cable and split them back up L & R at the mixer? I think it should work fine but wanted to see if anyone had any experience doing this.
    • #162926
      joecozzi
      Hello P9, just so I have it clear, you want to take the output of the MicroPitch Delay (MPD) with a dual mono to TRS cable and then use an adapter to accept that TRS and go back to dual mono? Yes, it can be done. Curious, what are you hoping to achieve by doing this?
    • #162930
      P9
      I am using a Friedman Buffer Bay and am one port short.
      FBBFront
      If I do it this way I can use just the one patch bay. The yellow area is what I am trying to solve.
      GigRigb
    • #162937
      joecozzi
      That should work. Don’t see why it wouldn’t. Best just to try it.
