Home › Forums › Products › Stompboxes › MicroPitch pedal question
- This topic has 11 replies, 3 voices, and was last updated 1 year, 3 months ago by
udi9.
May 21, 2022 at 9:23 am #163806
From time to time, when using my MicroPitch pedal, I see the LED of preset 5 flashing.
Can someone please explain why is it happening?
I think I read somewhere that it flashes when you change something in the preset, but here it happens even if I’m just using the preset and not touching any knobs.
May 21, 2022 at 9:52 am #163807
Hmmm, that’s peculiar. Are you using a an expression pedal with your unit?
May 21, 2022 at 9:57 am #163808
Hi Joe,
No, not using an expression pedal, but I do have catch-up mode enabled.
BTW, it happens regardless of the preset I’m using. I can be on preset 1 and still see preset 5’s LED flashing….(it flashes only for a second or two).
May 21, 2022 at 10:23 am #163809
Aside from blinking when editing a preset, I’m not aware of any reason the LED would behave like this. I recommend contacting support@eventide.com to document the behavior. Perhaps they can troubleshoot what is going on. In the event it’s a faulty LED, the pedal is under warranty.
May 21, 2022 at 10:36 am #163810
Thank you, Joe.
I’ve tried recreating the LED’s behavior for 45 minutes, but couldn’t. It seems that it’s just random.
I’ll try to pay closer attention to every action I do on the pedal, maybe I’ll understand when it’s happening.
Do you think that maybe I should try a factory reset?
Other than that the pedal works flawlessly and sounds incredible. One of the best purchases I’ve made in years.
I’ll also contact support, as you suggested.
Thanks again!
May 21, 2022 at 10:49 am #163811
It definitely couldn’t hurt to try both a fresh install of the firmware and a factory reset. Support may even ask you to do that first. Basically, following instructions beginning at 22:51 of this video.
I’m happy to hear you’re enjoying your MicroPitch Delay!
May 21, 2022 at 2:12 pm #163813
Those videos are fantastic – That’s what made me pull the trigger on this pedal 🙂
I reinstalled the firmware and did a factory reset. I’ll give it a couple of days and see if the flashing LED is coming back.
Thanks for your help, Joe!
December 29, 2023 at 10:36 pm #176954
HI!
I have absolutely the same issue with my Micropitch preset LED blinking every 30-50min
Did you fixed it somehow?
If not , despite this blinking is your still Micropitch alive and kicking?
December 30, 2023 at 2:54 am #176955
HI! I have absolutely the same issue with my Micropitch preset LED blinking every 30-50min
Did you fixed it somehow? If not , despite this blinking is your still Micropitch alive and kicking?My pedal was under warranty and I got a replacement unit. However, after a few months the new one developed the same behavior, so now I’m just ignoring it. Doesn’t seem to affect the usability of the pedal. Still works and sounds great. -
January 17, 2024 at 5:53 am #177438
Hey @udi9
I was talking to the Eventide support, looks like they found a software lag in the Micropitch. They now released a special update, please check your EDM.
I updated my device seems it is fixed now.
January 18, 2024 at 1:53 pm #177466
Thanks for the heads up @Restlesshead
I’ll definitely take a look.
