Just looking for some clarification please on running the Micropitch Pedal in a stereo W/D/W setup.
As per the instruction manual to achieve this my patch cable that runs “In” the pedal must be TRS and the patch cables running from “Out1 & Out2” must be TRS as well?
It only needs to be TRS if you want to connect a stereo signal into the MicroPitch. If you’re only coming into the pedal mono, then you just need another regular instrument cable and set the input switch to “mono.” If you’re coming out of a stereo pedal and need to go into MicroPitch in stereo, you’ll need a dual-TS to TRS cable; the TRS side goes into the MicroPitch. Set the input switch to “Stereo.’
