Using the EDM, I can’t seem to move a preset such as #46 up to #1 thru #5 so I can use the pedal features to change presets instead of MIDI. Can this be done?
Hello, on EDM simply drag the preset from 46 into the preset number you want. This will overwrite that spot automatically. If you don’t want to overwrite the preset, copy the preset to be replaced, paste it into an empty slot, and then move the new preset into place.
I tried that initially and it didn’t work. There was a save button highlighted that needed to be cleared out before the drag feature works. Got it going now. thanks..
