Middle Switch on ModFactor is Malfunctioning
Home Forums Products Stompboxes Middle Switch on ModFactor is Malfunctioning
    • #105428
      For some reason whenever i step on the middle footswitch to go to preset two on any bank, the preset engages while the switch is in the down position, but as soon as i release it, it jumps back to bypass. However, sometimes i can actually get it to activate and stay, but when i try to bypass it, it does the same thing, and jumps back to active. I'm hoping this isn't a hardware issue. Any thoughts? thanks
    • #117102
      Hi Blewmeaway,
      Since your inquiry may be a technical issue, I would like to email you offline to further troubleshoot this issue with you.
      Expect an email from me shortly.
      Best,
