Home › Forums › Products › Stompboxes › Middle switch stops working randomly on 6 day old ModFactor!!!!!
October 10, 2008 at 10:51 pm #105873
Mike Bernier
MemberHey guys,
Just bought the ModFactor last Saturday.
Love it. But two days ago while using it, the middle stomp switch
stopped responding. I tried everything including shutting it down for
a bit, but nothing worked. I continued to use it and then randomly
about ten minutes later the second switch started working again. The
same thing happend today. I'm so excited that I spent $400 on this
thing and 6 days in its giving me this kind of problem….Has this happened to anyone else?
Suggestions?
October 10, 2008 at 10:56 pm #117927
Sounds like an intermittent switch – apologies, but this can happen to the best of products.
You should contact support@eventide.com to get it resolved.
October 10, 2008 at 11:00 pm #117928
Mike Bernier
MemberDo you work for Eventide?
I already sent an email to them. Hopefully they can resolve the issue quickly.
I only posted to see if others are having the same issue.
Thanks
September 8, 2009 at 11:12 am #130108
joeyray
MemberJust today I emailed support with the same Problem. I too noticed the middle switch not working correctly from day one but, then it would work alright. Then it didn't. Seems I always had to push hard on it to get it to respond. My unit is over a year old. Well a few months back I went to new shoes that are very soft on the bottom and I thought that the shoe was to soft and wasn't operating the switch properly. This weekend I had to get down on my hands and knees and turn the fucking thing off. It's just plain sticking. Off/on. Dosen't want to work. The others are working fine.Like I said I noticed it from day one that it was contrary. Seem ed like I had to push on it extra to get it to work right. Well it's dead now.
I reprogammed my favorite settings to the other switch for now.
To top things off the unit went into some strange very low frequency unpleasant ocillation in the middle of a blues song. I thought the bass players was hitting all his strings at once going nuts or something but it was my amp. I thought it had blown a tube or worse. Nope good ole Timefactor freaking out and it wasn't even switched on. Unplugged it and plugged it back in and it quit for a few minutes then started the weird *** again. So I repeated the unplugging/plugging again. Same results. Then the band got a break. I repeated the before mentioned and same results again only after I switched out of the program that was in it's memory mind you it wasn't on at the time, no red light, did it finally get back to normal operation.
This thing is a little monster at times
TIMEMONSTER
made by FrankenTide
All kidding aside I love the pedal
It truly is a timemonster
Very powerful pedal.
Monstrous!
in summary my middle switch has been bad all along.
I will replace it and all will be better than ever.
Eventide,
just send me the switch or give me the part number and I'll solder that baby in.
Joey Ray
September 8, 2009 at 11:32 am #130109
joeyray
Membermine has done the same thing from day one
now a year later it finally died all together
Switch is definitely bad
Contacting eventide support trying to get another one
Joey Ray
September 9, 2009 at 9:37 pm #119019
oyarsa
ParticipantI had to return the first Time Factor I bought due to an intermitent problem with one of the switches. All is stable with the replacement unit though……..
Just a thought…..
September 9, 2009 at 10:12 pm #119020
joeyray
MemberEventide is sending me some extra switches free of charge.
I will do the repair myself.
If I damage the unit during the repair it will void my warranty if not all will be well and warranty will still be good and I'll have some extra switches.
That switch has been troublesome from day one. It finally gave up the ghost.
The thing I love about the timefactor is you never have to bend over and touch it during a show.
If you could only see the readout in the sunlight. (That's the only Complaint)
I'll let you know how the repair goes.
Joey Ray
September 22, 2009 at 7:29 am #130202
joeyray
MemberThe repair went perfect.
If you need a quick fix for switch prblems.
email me
October 4, 2009 at 12:17 pm #130286
RelicBert
MemberMy middle switch giving trouble sometimes, sometimes not.
Did JoeyRays fix, easy to be done. Looks like the switch working without problems now. Have to wait and see what happens in time . . .
But why is it the middle switch? Doesn't look different from the other switches . . .
November 13, 2009 at 7:45 pm #130590
robiox
MemberHi Joey!Could you send me information about how to order
and install the switch?Best RegardsRobertoyour email address is wrong -
November 14, 2009 at 12:00 am #130598
embrionic
ParticipantMy pedal went back to Eventide, was returned quickly and so far so good all switches working great.
November 14, 2009 at 9:01 am #130601
joeyray
Member22 Sep 2009 3:29 AM
If you need a quick fix for switch problems.
email me:
email is now correct
What did it cost you if anything?
November 14, 2009 at 1:44 pm #130602
Trazan
MemberI've had problems with, especially, the middle switch on mine since day one too…Are you guys talking about the switch being completely "dead" at times, or is it that it double triggers? It seems that mine double triggers and thus ends up doing nothing.
November 14, 2009 at 3:23 pm #130603
embrionic
Participantmy switch was intermittent, i never had double triggers, just no triggers. It would fail about one out of every ten presses, whether hitting it hard or soft. If your unit is under warranty you really should just contact eventide and get it back to them for the upgraded switches. They were fast on emails, I sent the unti in, they had it about a week and got it right back to me. All told it was just under two weeks round trip.
Mine seems to be working great, all three switches were replaced with a newer version switch, and unless I am imagining it, they feel more responsive, faster.
November 14, 2009 at 10:00 pm #130606
joeyray
MemberTarzan,
If you are able just take that thing apart and clean all three switches with alcohol
CLICK here to see disassembled TimeFactor
Click Here to see disassembled Switch
This is too easy
I cleaned mine months ago and have had no problem since
Now for my email
November 15, 2009 at 5:22 am #119474
john beddoe
Memberyup, exactly the same problem for me too and my pedal is only 1-2 months old. Its frustrating to have to send it to USA for repair as i live in Australia and use it 2 times a week for gigs!
November 15, 2009 at 4:57 pm #119477
Apologies – we have now fixed the problem but this does not help people who bought units previously.
If you are handy (or have handy friends) with a soldering iron, you might want to contact support@eventide.com and ask them to send you new switches.
November 16, 2009 at 5:34 am #130609
john beddoe
MemberI would like switches sent to me please! Especially as i live in Australia and cant be without the pedal for too long. I'm competent with a soldering gun. I've tried emailing support but i keep getting a message that it can't be sent (the message).
November 16, 2009 at 4:15 pm #130613
Trazan
Member"I've tried emailing support but i keep getting a message that it can't be sent (the message)."
Yeah, I got the same Daemon-response. It seems like the emails have been delivered now though.
November 16, 2009 at 4:15 pm #130614
Hi John, we received your email and our support technician has responded. Let me know if you did not receive it. Thank you!
December 2, 2009 at 9:06 am #130698
Trazan
MemberI just received some switches in the mail. However….from looking at
the back of the circuit board there seems to be two legs on those
switches? The switches I received have four legs and they do not seem
to line up with the solder holes on the circuit board. Did I receive
wrong switches? Or am I supposed to remove two of the legs and try to
seriously bend the two left in position…? Haven't desoldered the old
switches yet, but this it what it looks like to me 😉 -
December 2, 2009 at 3:18 pm #130700
joeyray
MemberThis is a picture of a new switch and the right switch.
I encounter no problems when installing it.
You have to use a de-soldering tool because it is a double sided solder joint.
The solder traces are fairly durable but, you could lift one if you aren't very careful.
This is not a job for an amateur.
I highly recommend popping the top off the switch and cleaning it first to see if this won't fix your problem.
It did for me and no problems with it since.
If any one wants to call me I can walk you through this.
Of course eventide may not even post this.
They seem to have a problem with videos and pictures.
But if they post this my number is:
740 351 0402
USA
or email me at:
Joey Ray
December 2, 2009 at 5:26 pm #130701
Trazan
Member -
December 2, 2009 at 5:49 pm #130702
achaput
ModeratorTrazan:
switches yet, but this it what it looks like to me 😉Hello,
You have to cut off the plastic legs to have the switch fit.
December 2, 2009 at 6:02 pm #130703
joeyray
MemberI'm sorry
this switch is out of the Time Factor
Joey Ray
December 2, 2009 at 6:18 pm #130704
Trazan
Memberachaput:
But, the switch I got has four contacts, in very different places than the two contacts on Joeyray's switch. My circuit board seems like it'd fit Joeyray's type…so I'm not sure how I'd get these in there.
December 2, 2009 at 6:24 pm #130705
joeyray
MemberOOPS!
This switch is for a TIMEFACTOR
I'm sorry if I caused any confusion
Only trying to help
Clean them switches first
It's so easy to do!
I don't know if the switches are the same for Modfactor and PitchFactor
Joey Ray
December 2, 2009 at 7:23 pm #130707
joeyray
Member[View:http://www.youtube.com/watch?v=1csp-U407y0:550:0%5D
I just called support
201 641 1200
then I listened to menu and then pushed zero (0) for operator
The person I spoke to said the switches were all the same in all the Factors. Then they changed their mind and said there was a change at one point. That they had had some trouble with some switches.
So at this point I'm going to assume that the switches are all the same and that person didn't know the full story on the switches and neither do I but, I do know this. If you pop the top off the old switches and clean them with alcohol and rotate the little plate around the switches will work like new again.
I just now popped the top off of one and cleaned it and put it back together.
It took less than 2 minutes!! WOW!
Turn the POWER OFF before working on unit!!!
Use a very small screwdriver and pry the button out of the switch…easy.
Clean all shiny parts.
Reassemble.
Works now!
You are crazy if you don't try this.
It has worked for me and others too.
Good Luck
Joey Ray
December 2, 2009 at 9:41 pm #130708
Trazan, it appears you've received incorrect switches. The picture above with *two* terminal contacts is the correct switch.
Please send me an email at bhaberman@eventide.com, thank you.
December 4, 2009 at 4:23 pm #130714
All, We've had a bit of confusion, but I've verified 100% that the switches above with the FOUR contacts are the correct footswitches in current use.
Sorry for any confusion.
November 29, 2010 at 8:56 pm #132203
EdMcKenna
MemberBest, most helpful post I have run across in these threads! Thank you!!
November 30, 2010 at 12:35 am #132205
Reckedtrek
MemberI had problems with the middle switch on my out of warrantee timeFactor. I emailed Eventide anyway. They had me send it back as well as my same era ModFactor, even though the MF was not having an issue. I paid shipping to them in NJ. They replaced all 3 switches on both boxes (6 total) free of charge! …despite the fact that both units were past warrantee. They had a bad bunch of switches on the units earlier on, and made things right. THAT is customer service, ladies and gentlemen. I had both units back in a week total TAT (I live on the east coast).
ANY company can get a bad bunch of switches… but a good company stands behind its products, and Eventide sure has. Thumbs up to you, Eventide!!!
November 30, 2010 at 1:37 pm #132210
Thank you for your kind words
December 1, 2010 at 12:43 am #132217
Reckedtrek
Memberbhaberman- no problem! You guys backed up your gear and I think it should be said. I worked in customer service for over 6 years. People are more than willing to complain to their friends, forums, etc… about something going wrong, but rarely will they take the time to say/post anything when something goes right.
December 2, 2010 at 2:58 pm #121074
David Carpenter
MemberHi Mike,
I'm a new owner of a Modfactor, great pedal.
I've been reading the posts regarding the middle switch. Alot of people seem to have problems with the "middle" switch. Since all three switchs are the same, I would think that the right most switch would wear more because its constantly used for cycling through all of the banks. Is there a technical reason for the middle one causing issues?
Thanks, David
