February 19, 2010 at 5:33 pm #106886
Easy question here. Have an Eclipse running v4.01. Got a Ground Control Pro, just need it to change presets at this point, but it doesn't do anything. I am fairly sure I have the Ground Control setup right. I have a 12-foot Monster 5-pin Midi cable from out on ground control to in on Eclipse, using power from the wall. I verified Eclipse global midi set to Omni with program changes set to on. The busy indicator on flash slot doesn't blink when I press buttons on the controller. Do I have to setup an external controller in the Eclipse for this basic functionality? If so, which settings should I change? Is there a way to see the messages coming in on the Eclipse?
Thanks for your help.
February 19, 2010 at 5:40 pm #120030
You should pretty much always see the BUSY indicator flash when you receive MIDI.
This suggests that the Eclipse is not in fact receiving MIDI. First check the GC settings (can't help you there) then try a different cable. If still no good, try and connect the GC to some other equipment to see if you can make it work.
February 19, 2010 at 5:58 pm #120031
Note that the light indicator does not respond to incoming MIDI if you have a flash card inserted though.
February 19, 2010 at 6:08 pm #120032
Indeed.
February 19, 2010 at 6:21 pm #131203
Good point, I tested the busy indicator by inserting a flash card to make sure the light works and it is fine, but I can't get it to light by Midi changes without a card. I will try to control something else with Midi tonight and let you know how it goes.
Thanks for the help everyone.
February 20, 2010 at 5:35 am #131204
have you set the ground contol and the eclipse to the same midi channel.also the right midi map for the eclipse.have you tried the cable in the midi out and the thu?
February 20, 2010 at 3:46 pm #131205
I set the ground control on channel 1 and the Eclipse to Omni. I didn't realize I had to set a midi map. Does the default work?
I didn't try the cable in the out, but I did try to use the ground control for my Podxt live and it didn't seem to do anything with it either. I wiped the memory of the ground control and that didn't help either. Thanks for the help.
February 21, 2010 at 9:24 am #131208
when i use my rocktron all access i have to use the midi out on the pedal to the midi in on the unit im controling.also im pretty sure the GCPro is made to be set up with the GCX and has a 5 pin midi that powers the GCPro from that(5 pin not 7pin)maybe that has somthing to do with it. but that kind of unit should be able to control anything.im using a lexicon R1 and its *** cause it is specific to the G2 unit but it has a relay to change channals hope you work it out dude.DB
February 21, 2010 at 9:34 am #131209
if i set to midi map one it starts from 100! if i start from map 2 i start from 01 i have to off-set it on my controller but if that was your prob the eclipse would give you some indication that there may not be a preset there? also check all your set up menu options like how your presets change?look for PMG .sorry i dont have mine infront of me.of for byoass and mute?
February 22, 2010 at 2:00 am #131211
I would be thrilled if I could change to an incorrect preset, but I see no sign of life. Am going to try to get a new cable tomorrow. At this point, I really hope it is a bad cable. Thanks again for trying to help me.
Rich
February 24, 2010 at 3:56 am #131223
Well, definitely a bad cable. I bought a cheap cable to test and it works with no issues at all. Thanks again.
Rich
January 11, 2011 at 9:37 pm #132555
I would like buy a Ground Control but the old version.
I have a question: The Control's display writes the Eventide's info?
for example: number of preset, the name of preset
Best Regards!
Bazsa82
January 11, 2011 at 9:47 pm #132556
Sorry – don't know about Ground Control, but my guess is that it doesn't write the info.
You should talk to Voodoo Labs to get information.
January 11, 2011 at 9:54 pm #132557
I will asked….
Bazsa82
January 11, 2011 at 9:58 pm #132558
It definitely does not write it, you have to manually name.
May 17, 2011 at 10:04 pm #133415
So I can write in the ground pedal memory?
June 10, 2011 at 12:20 pm #133504
On the Ground Control Pro you can edit the name of the preset and call it the same as the Eclipse preset …or any other name you like….I tended to name the presets after songs.
But I have not used an original Ground Control, only the Pro.
