Midi and Performance Footswitches
Home Forums Products Stompboxes Midi and Performance Footswitches
    • #174241
      cscotto
      Hi, quick question. If I assign the performance footswitches to be controlled by midi, will the pedal have to be in performance mode for the midi controlled performance switches to work, or does the midi assignment bypass the necessity of putting the pedal in perform mode? I know I can just try it, but a definitive answer will save some programming frustration since my H90 is buried in a rack making button presses difficult. Thanks.
    • #174242
      joecozzi
      You do not have to be in Perform Mode in order to control the mappings via MIDI.
    • #174248
      cscotto
