May 10, 2011 at 7:07 pm #107858violetpowParticipant
Hello Eventide,
i bought a H8000FW with 5.5 OS and after working a while i realized, that the midi controll settings in presets will not memorized after power off.
I have assigned 8 midi CCs in the H8000 setup. When i assign a parameter with the preconfuriated "assigns" 1-8 in a preset and set it up for spezial range (i.e. min/max 50%), but don't save the preset, after power off is the Midi assign still there, but with competelly other ranges.
Also i noticed, if you set 2 prarameter in a presets with i.e. assign 1 and 2, after setting up the assign 2 the setted range (i.e. absolute 500Hz) of assign 1 is gone and you have to do it again.
Are you familar with this bug and when it will fixed?
cheers
Mathias
May 10, 2011 at 7:20 pm #122073
violetpow:
You have to save the preset to keep the parameter MIDI settings – not a bug, it's the way the unit works.
violetpow:
Sorry – don't understand.
May 10, 2011 at 7:32 pm #122074violetpowParticipant
nickrose:
sorry for my bad english i'm a german.
In the H8000 setup you can configure 8 assigns to 8 midi CC.
Than you set in a preset assign 1 and assign 2 to two differnt parameters. At 1st you take assign 1 set i.e. dry/wet with a range of min/max 50%. After them you set assign 2 to feedback and use a range of min/max of 80%. After you pressing done at assign 2, the assign 1's range is back to absolute 100% (not min/max 50%)
I hope you understand 🙂
May 10, 2011 at 8:29 pm #133368
I see a possible bug where the maximum of the first assign is corrupted. This can be cured by re-entering it after having entered the second.
I'll enter it as a bug which should be fixed for the next release.
May 10, 2011 at 9:13 pm #133369violetpowParticipant
ok, thanks
