- This topic has 7 replies, 3 voices, and was last updated 1 year, 7 months ago by
Eventide Staff.
June 17, 2023 at 9:25 pm #171998
afewster
ParticipantI’m sending automation from Logic to H9000 to enable/disable the effect bypass – while the bypass can be visually seen to change back and forth in emote, the effect isn’t actually bypassed until I manually click bypass (even though I can see the effect changing from active to bypass via midi).
Apple M1 Pro Venture 13.4
Logic 10.7.8
Emote 2.1.2
H9000 2.1.10
June 20, 2023 at 12:24 pm #172028
Thanks for reporting this. I can confirm this issue using Ableton Live as well. We’ll have this fixed in the production release.
July 18, 2023 at 12:41 pm #172491
H9000 beta firmware 2.1.13 has been released and fixes this issue. Please use Emote to update your H9000 and let me know what happens.
July 18, 2023 at 3:34 pm #172497
bsfreq
ParticipantH9000 beta firmware 2.1.13 has been released and fixes this issue. Please use Emote to update your H9000 and let me know what happens.
Ok, thanks but where is the download link for Emote? Or is there a typo in Beta thread, and you actually mean the FW is compatible with Emote 2.1.2 which is actually available as download??
“H9000 Public Beta Firmware 2.1.13 is now available. This firmware release is compatible with Emote 2.1.12, please use Emote to update your H9000’s firmware.”
July 18, 2023 at 3:42 pm #172499
That was a typo in the post, thanks for pointing that out! There are no changes to Emote and you can continue to use Emote v2.1.2.
July 18, 2023 at 3:43 pm #172500
bsfreq
ParticipantOk great, thanks for the quick reply!
July 19, 2023 at 11:45 pm #172535
afewster
ParticipantThanks for the fix – confirmed it’s working as expected in Bitwig 5.0 with firmware 2.1.13
July 20, 2023 at 10:36 am #172540
Good to hear! Thanks for confirming.
