Midi Bypass Command = True Bypass?
Home Forums Products Stompboxes Midi Bypass Command = True Bypass?
    • #107976
      JazzMac251
      I'm going to buy a modfactor/timefactor in the near future and I'm going to be controlling them via a Liquid Foot Jr.
      I read that you can send bypass commands to the these stompboxes via MIDI, which is amazing, but I need to know if the stompbox responds to that bypass command by engaging its TRUE bypass mode or if it basically just turns the dry/wet knob all the way to "dry".
      I'm hoping for true bypass, but I think that would require an extra bit of effort, so I'm kind of expecting the "dry knob" thing. I think the "dry knob" approach would probably lead to considerable tone-suck.
    • #122369
      The bypass mode is configurable, to either relay (TRUE) bypass or dsp (wet/dry) bypass.
      This setting will apply to either MIDI bypass or footswitch controlled bypass.
      So, it should do what you want.
    • #122370
      JazzMac251
      Guys, your gear and your forums are both ****ing amazing.
      <3 Big Smile
