Using a CAE RS-10 foot controller, I've tried various volume pedals (as the manual says) into the expression pedal jack to send MIDI CC to Pitch Factor. The CAE doesn't have a pedal calibrate function.
Reading the PF display while sweeping the pedal, I'm getting 0 to 99. Not quite an octave. Not quite good enough:-) Even shorting tip to sleeve, pedal disconnected, still just 0 to 99.
Using an expression pedal straight into the PF, 0 to 100 no problem.
Any ideas of a solution? Does the PF have a hidden calibrate function that would solve this?
Thanks in advance,
Paul
