There are various ways, depending on which product you are using.
One is to add an EXTCON module – you will have to connect it to a menu to adjust the CC numbers, etc.
Another is to select a KNOB or similar, then MIDI/Add Remote, which will add a different type of remote module which can be programmed from within Vsig.
