Home › Forums › Products › Stompboxes › Midi Command for switching
Hello 🙂
Is there a way to create a midi command to switch between select mode and the two layers of the perform mode?
greetings
You can use a MIDI CC to select Bank, Perform, or Select mode. There is currently no way to toggle the 2 pages of Perform mode, but we may add this option in the future.
https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/appendix/global.html
Yes I saw the mapping you linked here. But I can’t see the Cc number and value in there. Where do you generate it / see it?
Sorry for the misunderstanding. I would suggest using H90 Control for the mapping, since it is easier to see everything. Please see System Settings > Global Control at the bottom of the page: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/h90-control/system.html
You can also make the mappings on the pedal itself from System > Global > Pedal Control: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/system-menu/global.html
Thank you for your replies. That really helped!
