Midi Connection with Alexander Pedals
Home Forums Products Stompboxes Midi Connection with Alexander Pedals
  • This topic has 4 replies, 3 voices, and was last updated 3 years ago by nickrose
Viewing 3 reply threads
    • #162678
      Rocaste1
      Hi, I’ having trouble midi-controlling an Alexander Pedals’ Space Race through the H9. I use a Boss MS-3 as midi controller and for some reason when I connect the Space Race directly to the MS-3, I don’t have any problem. No problem either when, between the H9 and  the Space Race, I connect another pedal, specifically a GFI Synesthesia.
      I contacted support for Alexader Pedals/Disaster Area Designs and they concluded “That suggests to me that the H9 doesn’t connect pin 2 of its MIDI port to earth / ground.” Is this assessment true? Is there something to be done? is something wrong with my unit?
    • #162680
      Keoki
      NM
    • #162682
      Mr. Alexander is correct about older H9’s (before about serial 16329).
      See https://www.eventideaudio.com/forums/topic/h9-modification-for-midi-power for more information.
      • #162687
        Rocaste1
        My H9’s serial is 34xxx. I’d imaginé this is a newer version. Am I  right? In this case, how can I check that the unit is working properly?
    • #162688
      Given your serial number, you don’t have the above mentioned problem.
      If your unit is still under warranty, you could send it in to be checked.
      But, be aware that there are any number of issues that could cause this sort of problem.
      Most commonly, bad cables and grounding, or incorrect configuration.
