MIDI connectivity advice for Micropitch pedal
Home Forums Products Stompboxes MIDI connectivity advice for Micropitch pedal
Viewing 3 reply threads
    • #116523
      Read774
        Hi, i have recently purchased the micropitch pedal and intend to put it through the effects loop of my kemper so that i can use 4 different presets on the pedal within the various rigs i use on the kemper.
        I am not the greatest technically and am seeking some clarification as to how i can program the micropitch to patch change via midi when i switch rigs on kemper.
        I am getting the feeling that i need to invest in a midi box in order to do this, but am wondering whether there is an alternative method that wouldn’t require any additional costs, as for the price of the pedal i am a little surprised that it doesn’t have midi connection capabilities already built into the pedal.
        Any advice would be welcomed.
        Thanks in advance, Ben.
      • #157972
        joecozzi
          Make sure the MicroPitch Delay is set to the MIDI channel your controller is using to communicate with your pedal. To learn how to set the MIDI channel
          3:03 – Learn to enter System Settings
          7:24 – Learn how to set EXP input for MIDI Box or MIDI TRS.
          13:38 – Learn to set MIDI channel
          https://youtu.be/0xcWsiw3Wqc
          Read774 wrote:
          I am getting the feeling that i need to invest in a midi box in order to do this…
          It all depends what kind of MIDI connections your controller uses. The standard protocol uses 5-pin MIDI DIN, in which case you will need to invest in a MIDI Box to convert 5-pin DIN to TRS. MIDI a over TRS is a newer protocol that helps pedals remain compact, and newer controllers on the market use this capability. As stated above go to 7:24 to learn about the differences.
          Once you have programmed the MicroPitch Delay to function on the correct channel, you need to program your MIDI controller to send a program change number (1 – 127) that corresponds to the presets you want to access.
        • #157975
          Read774
            Thanks very much for the quick response, I’ll check out the video now. Cheers, Ben.
          • #158015
            camn
              FYI it is just copper, the MIDI-TRS connection. If you have a mate who is handy with a soldering iron, they could chop the end of a standard MIDI cable and wire a TRS end on the thing with, like, zero effort.
