The PF manual lists MIDI parameter destinations FS1, FS2, FS3. Can these be used to switch between the presets in the currently selected bank while in bank mode? I would like to switch presents via a MIDI controller.
FS1-3 operate the footswitches in the alternate mode – example, if you are in BANK mode, they will operate the footswitches in PLAY mode. And vice-versa.
Normally, the best way to select presets via MIDI is to use MIDI Program Change.
