Home › Forums › Products › Stompboxes › MIDI Controller Expression pedal vs AUX Expression Pedal
March 9, 2017 at 6:07 pm #145897
You will hopefully get comments from other than me, but…
1) If you plug an external pedal into a MIDI controller, you may encounter the same issues as plugging an unsuitable pedal into an H9.
2) There is a risk with a MIDI pedal of a slight "rubberiness," due to the indirect connection. Depends on the pedal.
3) On the bright side, it frees up the AUX socket.
March 9, 2017 at 10:42 pm #114053cljffordParticipant
I read that the H9 works with certain Expression pedals and not as well with others, so I was looking at maybe getting a Mission SP-H9 and an AUX switch. Then I read more about MIDI foot controllers and learned that certain ones offer even more control and options than a single pedal and 2 or 3 AUX switches.
I am wondering if it is the same difference to the H9 if it gets the expression pedal data from MIDI or from the AUX? Through a MIDI controller, it wouldn’t matter if the expression pedal was a $140 Mission or a $40 Moog EP-3, right?
There’s a context for everything but does it always make more sense to get a MIDI controller, with it’s expanded control options, or are there advantages to using the AUX that I am not aware of?
Correct.
However, H9 can’t handle expression through MIDI very well, it’s not as smooth and fast as using an expression pedal straight into the AUX/EXP port.
March 10, 2017 at 5:22 pm #145910brockParticipant
A continuous pedal action would be more versatile than switched input. The advantages of Aux switches – or switching over MIDI – are the instant jumps between two parameter values, the ability to set specific limits on those values (or reverse them), plus a choice between momentary or latching behavior.
There are also ‘hybrid’ methods for overlaying a switch action on the expression pedal mappings. Ideally, you’d have both types of control (continuous & switching) available. Select one based on the effect that you’re after.
March 11, 2017 at 1:16 am #145916cljffordParticipant
Thank you for the informative replies.
