- This topic has 8 replies, 4 voices, and was last updated 3 months, 4 weeks ago by wojtek1959.
November 4, 2023 at 1:55 am #175423javartinParticipant
Hi, would anyone recommend any Midi controllers (preferable with screen) for H9K (could Faderfox EC4 work??)? I figured that it’s not that convenient tweaking the emote knobs using mouse clicks in a long session. Thanks ~
November 4, 2023 at 2:27 am #175424joeydegoParticipant
If emote is used as a session plugin you know you can write the automation, right?
either way, this controller serves my H9000 needs well. Faders, knobs and buttons under 100 bucks
November 4, 2023 at 11:24 am #175432joeydegoParticipant
Let us know what you end up with and how you like it. The one I posted is bus powered so as soon as you plug in the USB you’re up and running. That’s a plus.
November 7, 2023 at 9:39 am #175486
FaderFox EC4 works great with the H9000 (or any MIDI device I’ve tried). If you want something with a screen that is fully customizable, the EC4 is a great choice.
October 7, 2024 at 5:08 am #185217wojtek1959Participant
I connected Bechringer x touch compact to H9000 via midi din. For now it only works with encoders.
October 7, 2024 at 10:31 am #185221wojtek1959Participant
I connected Behringer x touch compact to H9000 via midi din. For now it only works with encoders.
October 8, 2024 at 8:40 am #185240
Sorry, I’m not familiar with this controllers. Any controller that can send MIDI CC messages should work fine if the MIDI channel is set correctly.
You can try using a MIDI monitor app to confirm that the faders are sending the correct CC messages on the correct channel.
October 8, 2024 at 8:58 am #185241wojtek1959Participant
I am a newbie here on the forum. I bought the Behringer controller relatively recently. I consider the fact that I managed to connect the X touch compact to the h9000 a success. All encoders work correctly after mapping with the h9000 -> only these faders. But that’s okay. I’ll dig into the X touch compact and maybe something will come up. I’m optimistic
