Midi Expression Pedal
Home Forums Products Stompboxes Midi Expression Pedal
    • #146810
        You don't say what pedal you are using, so I will reply for an H9.
        The manual does not say, but following "TAP" in the destination list you will find "EXP", which is the expression pedal.
        Don't understand "What KB gives the "default" functionality?".
        Also don't quite understand "Where do I find", but you may find  H9 Algorithm Guide  useful.
        • #146811
          nickrose wrote:
          You don’t say what pedal you are using, so I will reply for an H9.
          The manual does not say, but following “TAP” in the destination list you will find “EXP”, which is the expression pedal. How do I map the Midi pedal CC messages to do the same thing?  Si a mapping to a KB parameter or are you saying the EXP destination does that rather than a specific KB Paramter?
          Don’t understand “What KB gives the “default” functionality?”.
          Also don’t quite understand “Where do I find”, but you may find  H9 Algorithm Guide  useful.
          Sorry – let me clarify.  I am using an H9.
          When I plug a TRS expresssion pedal into the “EXP” jack on the H9 the pedal will do a default fucntion on each preset (sometimes nothing).
          My understaning is that you must map a CC to a KB which will caude the CC to control that parameter.  How do I know what, say KB6 maps to on each algo? (are they just 1-10 on the Algo guide?)
      • #114269
        If I want an external midi expression pedal to map the the default expression function (i.e. perfrom what happens when I plug in a TRS expression pedal) how do I do this?
        Page 35 of the UM states to map KB to a CC, which are defaulted to KB0 – C22 etc.
        Where do I find the list of what KB0 (paramter 1)  etc control for each algo/preset?
