MIDI from H9 to iPad
Home Forums Products Stompboxes MIDI from H9 to iPad
Viewing 10 reply threads
    • #116330
      Rezzy777
        I know that the H9 can receive MIDI, but is it able to send MIDI as well?
        I have OnSong installed on my iPad and I was hoping I could use the MIDI from my H9 to flip through pages of OnSong.
        I really don’t want it vice versa 😉
        Does anybody have some experience with this? Many thanks in advance!
      • #157040
        bohan
          Rezzy777 wrote:
          Hi, I know that the H9 can receive MIDI, but is it able to send MIDI as well? I have OnSong installed on my iPad and I was hoping I could use the MIDI from my H9 to flip through pages of OnSong. I really don’t want it vice versa 😉 Does anybody have some experience with this? Many thanks in advance!
          This can only be done through MIDI adapter or USB adapter cable. In that case, you just take H9 as a normal MIDI device, which can send out MIDI PC messages when you switch presets by pressing the right footswitch.
        • #157042
          Rezzy777
            Really? What’s the difference between wired and Bluetooth MIDI?
            (I’m sorry, I’m quite new to MIDI)
            And how can I disable the default setting of each FS? I don’t want to switch presets when I’m just flipping pages 😉
            Thanks again!
          • #157045
            bohan
              H9 supports Bluetooth for H9 Control connection but it doesn't support Bluetooth MIDI. It can receive MIDI messages wirelessly if you set up correctly in H9 Control but it cannot send out MIDI messages wirelessly.
              H9 can transmi MIDI PC messages only when you switch presets. You cannot have the H9 do nothing but only send out MIDI. Sorry, H9 is a pedal but not a MIDI controller.
            • #157046
              Rezzy777
                Wow, that’s a very clear answer, thank you so much!
                But if I really want to use Bluetooth, is it an option to connect a CME WIDI MASTER to the MIDI OUT of the H9? Or doesn’t that make a difference at all?
                And what about the BARN3 OX9, is that capable of just sending MIDI instead of also switching presets?
                What do you think?
              • #157048
                  We have not yet tested the Widi with the H9, but expect it to work fine.
                  Note that early H9s do not provide the power the Widi needs (but see other posts about a fix for this). Later ones will be fine.
                  The Barn3 is a simple (but useful) switch so does not send MIDI.
                • #157049
                  Rezzy777
                    Ah, that’s a pity. So no solution there as well. Thanks anyway for replying so quick and clear!
                  • #157053
                    Rezzy777
                      So to bother you again, I just had a new idea 😉
                      I also own a Line 6 Helix LT which can actually connect to my iPad and send MIDI
                      (therefore the Helix is also able to flip through the pages in OnSong), but it’s all connected through a USB cable.
                      Since I don’t want the connection between these 2 devices to be wired, I just thought of another solution:
                      How about if I send a MIDI Command from my Helix via the H9 to the iPad?
                      Will that be a reliable connection? What do you think?
                    • #157062
                      Rezzy777
                        The serial number of my H9 is 27203, is that okay?
                      • #157075
                        Rezzy777
                          Just wanted to let you know that I now have a great MIDI connection between my Line 6 Helix LT, my H9 and my iPad.
                          – LT to H9 for switching Presets of the H9
                          LT via H9 (THRU) to iPad for switching songs in OnSong.
                          I haven’t been able to test this thoroughly and in a live situation, but thus far I am excited that everything seems to work as expected with the help of my new CME WIDI MASTER! 🙂
                        • #157077
                          Rezzy777
                            …and the great help of all of you guys off course! 😉
                            Thank you so much for helping me out here!
                          • #157054
                            bohan
                              Well Helix is the same as H9, which doesn't support Bluetooth MIDI.
                              You'll need something like these to work with your Helix.
                              https://www.cme-pro.com/widi-jack/
                              https://www.sweetwater.com/store/detail/MDBT01–yamaha-md-bt01-bluetooth-wireless-midi-interface
                            • #157055
                              Rezzy777
                                Got it. Is it possible to put any of these into the MIDI OUT of the H9? And which one is better, do you have any experience with those?
                              • #157061
                                bohan
                                  What's your H9's serial number. You may want to look at this post: https://www.eventideaudio.com/community/forum/stompboxes/h9-modification-midi-power
                                  I have tried the yamaha one before, but I cannot guarantee anything nor can I recommend either one.
                                  If I were you I may go with https://www.cme-pro.com/product/widi-master/ as it's newer. But again, I don't guarantee and you should do more research if you are sure this is something you want.
                                • #157064
                                    Anything after 16273 is good, so you will be OK. I plan to try out the Widi next week.
                                  • #157066
                                    Rezzy777
                                      Oh that’s great!
                                      I just ordered mine! 😉
                                      Thanks again!
