Midi Learn issues with Latest beta.
Home Forums Products Rackmount Midi Learn issues with Latest beta.
    • #171917
      Jago_Marris
      Anyone else having issues with the midi learn mode in Emote. Using the plugin in Logic on Mac.
      I can assign some items. Such as the new Pan control in the plugin.
      But when I try and set the knobs for Automation on a plugin with knobs (e.g.  Chorus). It will not accept the learn command and assign the function to the knob.
      Some Algos allow mapping, others don’t.
      E.g
      Simple Compressor will Map. (Slider)
      Q-Wah will not (knob)
      Thanks
      Jago
    • #171922
      Thanks for reporting this. I can reproduce this, it seems like an issue that specifically relates to H9 algorithm parameters. We’re looking into it, if you find that there are any other non-H9 parameters that also have this issue, please let us know.
      • #171925
        Jago_Marris
        Thanks. If I find other types I will let you know.
    • #172493
      H9000 beta firmware 2.1.13 has been released and fixes this issue. Please use Emote to update your H9000 and let me know what happens.
