Home › Forums › Products › Stompboxes › Midi Mapping H9 Control
May 13, 2021 at 10:36 pm #116494
t3hsauce
ParticipantI’m considering buying a H9 Max pedal and I looking for more resources on midi mapping the pedal functions. I’ve downloaded the Control App for Mac and connected an Allen and Heath Xone K2 midi controller to attempt mapping in demo mode. I have managed to connect the K2 via Settings -> Connect Midi Device to Eventide Device, and I can see midi data transmitted from the controller.
What I am missing is how to actually map the controls to the various parameters in the algorithms. Pedal Settings -> Midi Settings -> Assign MIDI CC messages to pedal functions seems to be the correct panel, but the mapping parameters are all listed as MIDI CC values. All of the data transmitted from the Xone K2 are midi hex values and I’m not sure how to actually assign anything.
Can anyone help me out here or point me in the right direction?
May 13, 2021 at 10:49 pm #157846t3hsauce wrote:What I am missing is how to actually map the controls to the various parameters in the algorithms. Pedal Settings -> Midi Settings -> Assign MIDI CC messages to pedal functions seems to be the correct panel, but the mapping parameters are all listed as MIDI CC values. All of the data transmitted from the Xone K2 are midi hex values and I’m not sure how to actually assign anything.
Take a look at the K2’s User Manual. On page 14-18 there’s a guide that indicates what CC#’s are mapped to each encoder, knob, and Button. Make sure that whatever parameter or function you want to map with a respective control on the K2 that it’s using the same CC# in the “Assign MIDI CC Messages” section of H9 Control. Also, make sure you don’t accidentally map two parameters to the same number.
To simplify things, remember that you can map various parameters of a preset to the ribbon controller, so that with one CC# assigned to the “expression pedal value” you can change many parameters at once. You’ll have to program your expression ranges on H9 Control for this to work. And it works really well.
May 15, 2021 at 9:51 pm #157851
camn
ParticipantAnd here is Hex vs. Decimal conversion chart for CC:
https://www.midi.org/specifications-old/item/table-3-control-change-messages-data-bytes-2
