MIDI mapping issue on H9 algos on new firmware
Home › Forums › Products › Rackmount › MIDI mapping issue on H9 algos on new firmware
Viewing 4 reply threads
    • #172389
      stevepretty
        Hi guys,
        Loving the new firmware, and not had any problems until now. Especially loving the fact that there is now a trigger option for the more advanced phased loop stuff – thanks for fixing that as I use this stuff a lot live, and this is a gamechanger.
        Trying to map some parameters for a live show, and all working smoothly until I get to some of the H9 algos. Specifically, Resonator and Quadravox don’t seem to be able to map parameters via learn. Have tried different controllers etc etc and everything else working perfectly, so it’s not a connection thing. I can do it manually, but thought I’d flag this as it’s a minor annoyance and I suspect a relatively easy fix.
      • #172392
        stevepretty
          Update: programming manually using CC number also doesn’t work. But the same fader works perfectly on both learn and manual mapping mode on non-H9 stuff.
        • #172396
          Jago_Marris
            I raised this with them in June on an earlier thread. They can reproduce the issue. So hopefully a fix is not too far away.
          • #172422
            stevepretty
              Ah sorry, missed that. Thanks for letting me know. Bit of a howler, so hopefully it’s fixed soon.
              • #172429
                  Sorry for the inconvenience, we’re working on getting out a fix for this ASAP.
              • #172490
                  H9000 beta firmware 2.1.13 has been released and fixes this issue. Please use Emote to update your H9000 and let me know what happens.
