Home › Forums › Products › Stompboxes › Midi Micropitch Delay & GCX Ground Controller
- This topic has 4 replies, 2 voices, and was last updated 4 years, 3 months ago by
moosemusician.
May 3, 2022 at 7:16 pm #163626
Greetings
I bought the Micropitch Delay pedal and I cannot get my GCX Ground Controller to communicate preset changes using my GCX Ground Controller. My midi path is GCX Ground Controller -> GCX Audio Switcher -> Micropitch Delay. I used the EDM to set EXP to TRS Midi and I am using a Midi 5 pin to TRS cable. Both devices are set to Midi Channel 1 and I cannot change presets with my GCX ground controller
thanks
May 3, 2022 at 8:00 pm #163627
Is the MIDI 5-pin DIN to TRS cable wired using the MIDI type-A wiring where Tip is connected to pin 5, Ring is wired to pin 4, and sleeve is wired to pin 2?
What messages have you programmed the GCX buttons to send? Are you sure the GCX is sending on channel 1 and the MicroPitch is receiving on CH1? have you tried setting the EXP input to MIDI Box instead?
May 3, 2022 at 9:23 pm #163629
Yes, I believe so, I purchase this from SW -> BEMBQL2 2′ 1/4″ TRSA to MIDI DIN. I am only sending preset changes from GCX, configured for 4 Presets/Bank mode. I have used this configuration successfully to control/send messages other midi devices, it will select presets from 1-4 of the connect device. I am sure GCX is sending on channel 1 and I used EDM to change the midi default from omni to channel 1. I dont have a midi box, my understanding from the youtube video 2 that I only needed a midi 5 pin to TRSA
May 3, 2022 at 10:56 pm #163630
When you adjusted your settings on EDM, did you make sure to click UPDATE SETTINGS on the top right to store them to the pedal?
May 4, 2022 at 8:36 am #163631
Yes, I clicked the Update Settings on the top right to store. I also tried the “midi box” setting, no luck.
