Midi not working on H9 when USB Connected
Home › Forums › Products › Stompboxes › Midi not working on H9 when USB Connected
    • #177410
      dmbpettit
        I currently have two H9s, a Tonex, and a Morningstar MC6 Pro. I have installed a USB hub under my board so that all the pedals can have their USB cables always connected which is very convenient for plugging into a computer. The problem with this setup is that the H9s do not respond to Midi signals sent via a 5-pin cable by the Morningstar when a USB Cable is connected. Even if the other end of the cable isn’t connected to anything. It seems as though MIDI is disabled if the H9 detects the presence of a USB cable. Can this be fixed?
      • #177420
          This is the expected behavior, you cannot connect both USB and DIN MIDI at the same time on the H9. This cannot be changed, sorry for the inconvenience.
        • #195266
          breeyark
            Is there a way to disable the USB port?  It would have to be through some magic combination of buttons/menu’s from the onboard control panel/buttons…..
            • #195267
                No, this isn’t possible.
