Midi on The Rose
Home Forums Products Stompboxes Midi on The Rose
Viewing 4 reply threads
    • #171009
      Tokyo tapes
      As much as I love how the Rose sounds it’s really testing my patience when setting it up with midi. Here’re some questions:
      I’m using the Midi through on the H90 to send midi to the Rose. It doesn’t work. I read somewhere that you can’t send midi direct but you have to use something like the Midi Box 4 from DA. Is this correct? No matter how you solder the 5-pin-TRS cable coming out of the H90 Through?
      When looking at the “Eventide Rose – Basic MIDI Assignments” video it shows the midi channels differently on the shape latter than what is shown in the Reference Guide. Which one is correct?
      It would probably help immensely if you’ve had a proper manual for the Rose. Just sayin’
    • #171011
      Sorry to hear of your frustration.
      Yes, you must use a MIDI DIN to TRS convertor box.
      The easiest way to configure the MIDI settings on the Rose would be connecting it to the Eventide Device Manager app and setting the MIDI channel there – https://www.eventideaudio.com/software/device-manager/
      Let me know if you need any further help.
    • #171015
      Tokyo tapes
      Thank you!
      I kinda figured that. Could you please explain what the Midi Box do that a cable don’t?
      I’ve got my pedals mounted in a way that obscures the USB jack. Could you please point me to which info for midi channels that is correct?
    • #171021
      joecozzi
      Here’s a graphic showing the correct MIDI settingsMIDI.001
    • #171030
      Tokyo tapes
      Thank you!!!
