MIDI OUT and THRU for VSigfile (and correction to my earlier post)
Home Forums Products Vsig and Preset Development MIDI OUT and THRU for VSigfile (and correction to my earlier post)
    • #106638
      J20056
      I find that I need to use MIDI OUT in order to be able to use VSigfile. It doesn't work with MIDI THRU. On the other hand, my MIDI chain (4 devices including the H7600) only works with THRU and not OUT. Is this "normal" behavior? Is the only way to get both working at the same time by using THRU for the MIDI program changes and the RS232 Serial port for VSigfile? Or is there an internal setting to fix this?
      Thanks
    • #119485
      IDeangelis
      MIDI OUT is the choice as MIDI datas are being generated in the computer. MIDI THRU is only used to bridge MIDI datas received by unit and passed along to the next. All normal here.
      You may need a complex MIDI management device to get your OUTS and THRUS working together…or a switch to serial COM for Vsig (the best choice).
      best
      I
