Home › Forums › Products › Stompboxes › MIDI PC causes my H9 to mute
August 6, 2018 at 3:48 pm #114883
Imerkat
ParticipantHello, I have a problem and not sure how it’s happening. When my Helix sends PC messages to the H9 it first display a parameter setting (as if I moved the the knob) and then loads the preset but it is mute. I have to then unplug and plug it back to get it to work. Any advice? thank you
August 6, 2018 at 6:03 pm #149876imerkat wrote:
Hello, I have a problem and not sure how it's happening. When my Helix sends PC messages to the H9 it first display a parameter setting (as if I moved the the knob) and then loads the preset but it is mute. I have to then unplug and plug it back to get it to work. Any advice? thank you
What is muted? All sound or just the effect? What did you unplug and plug?
August 6, 2018 at 6:51 pm #149877
Imerkat
Participantall sound is muted. I have to re-plug the pedal for it to sound again. the routing is in normal with reverb tail FX buffered or what have you.
What if you press the left footswitch, or change presets on H9 when the sound is muted? What does the display show when H9 is muted?
August 6, 2018 at 11:56 pm #149879
ParticipantI seem to remember reading about the Helix using CC #32 for Setlists. In the H9, CC #32 is mapped to Input Volume by default. Sending a low CC value to the H9 would effectively mute your input. If that’s the case, you can reassign Input Volume to another CC#, or No Mapping, if you’re not using it. In the H9 Control app: [Pedal Settings -> Assign MIDI CC messages to pedal functions -> Input Volume].
August 8, 2018 at 2:16 am #149881
Imerkat
Participantyup. must have been it. took of CC of the mapping and did the trick.
Much obliged for your assitance, Thanks ya’ll!
