MIDI Program Change Transmit Map???
Home Forums Products Stompboxes MIDI Program Change Transmit Map???
Viewing 0 reply threads
    • #111329
      Unfortunately will have to replace the H-9 due to this, as I need this to control an amp:
      <<Note: When an H9 Preset is recalled with a MIDI program change message, MIDI
      Program Change messages are not generated. >>
      Why not make it still generate a Midi Program Change Map, when receiving from a food controller? I assumed it would do it till i came across this? any chance this can be fixed with firmware any time ?
      Thanks.
