Midi Program Change Transmit on Mod/Pitch/TimeFactor
Home Forums Products Stompboxes Midi Program Change Transmit on Mod/Pitch/TimeFactor
    • #106469
      Rikkie
      Normal
      0
      21
      false
      false
      false
      MicrosoftInternetExplorer4
      I
      hookt up a Midi pedal board -> Modfactor-> NovaDrive (from TC) By Midi
      Everything
      works well.
      But:
      The
      NovaDrive has only 18 presets and  doesn’t
      have Prog. Chance Mapping
      So
      i want to use the  XMT
      MIDI Transmit Channel Control from the
      Modfactor to control one of those 18 Presets to the Novadrive
      I did:
      – Set
      the MIDI Transmit Channel    ch1 NovaDrive also at ch1
      – i Create
      a MIDI Program Change Transmit Map  for
      example 13.1 > 1,   13:2 >2…..
      – MIDI
      Program Change Transmit Enable – on
      – MIDI
      Transmit/Thru Select – XMT
      So now
      if i choose a preset on my pedal board the ModFactor does the same as before
      (thats ok), but the Nova Drive doesn’t
      do anything.
      ONLY,
      if i hit a Button ON the ModFactor (in
      bank mode), the NovaDrive chance to the desire preset.
      What do
      i do wrong,
      I just
      want to control everything by my pedal board
      Thanx in
      advance
      Rik
    • #119103
      If you use MIDI program change to load a preset on the MF it does not send a program change. Sorry.
      You will probably have to set up the MF in MIDI thru, and use the Rx MIDImap such that you can send Program Change messages the TC will accept and also load the right presets on the MF.
